3 members (Rastus, Alan Patterson, +8Rich), 201 guests, and 25 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
so I removed it.
Or more correctly, relocated it. Referring of course to that fugly factory rectifier that afflicted the early 5 speeders. Used one of the alternative P/Ns found on this forum, and following a comment from Phil Bleazey mounted it on the front edge of the body using rubber washers (plumbing supply parts) to separate it from the paint. Pretty much disappears from view, but has a straight shot to cooling air.
Late 2012 M3W
Love your headlights, and would appreciate a cross reference.
thank you,
Tom
If you hadn't taken the close-up I would never have spotted its new location! thumbs
[quote=Piloto]Love your headlights, and would appreciate a cross reference.
Tom,
Headlights are from Speedwaymotors.com. Search there for "tri bar headlights.
Several web retailers sell them.
Not the easiest install as the spring clips Morgan uses are the old school motorcycle type. Also, by using this type of headlight you lose the sidelight feature of the original lights. They do make tri bars with built in turn signals, which may allow for the sidelight feature.
Late 2012 M3W
