11 members (Jon G4LJW, MATTMOG, mph, Graham, G4FUJ, Morganmike, nick w, bmgermany, Hamwich, RedThree, Mogdavid, MJF), 222 guests, and 36 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Page 3 of 3 1 2 3
Originally Posted By Lowflyer
Antiseize had already been applied previously i must say i always use it, however NGK recommend that you do not use it due to the inaccuracy of the torque setting if used. For me its a must, same with wheel bolts.....never lost a wheel in 53 years!!
Just had a look at mine ( 2011 Duratech running on originals) and though all corroded, front and rear were the worst. They are platinum plugs & were labelled both as Fomoco and NGK with part number AGF S 22FE13J. (So not worth arguing any more over whose plugs are best!)
As I couldn’t find these on flea bay, spoke with very helpful guy in NGK Technical Dept and he says equivalent is PTR 6F 13. Mentioned corrosion issue and he said that the metal bodies are treated with a lubricant coating during manufacture, which may deteriorate. Maybe that also explains the “no need to use anti seize”. Torque settings for alloy heads is 10 to 20 nM.
(You may also see PTR 6D plugs and am told they are virtually the same but different packaging as different numbers are used when plugs are made for various companies.)
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Good info there Deejay!!
This highlights the need of a cover of some sort to exclude rainwater ... Much as the louvres look the part I wonder if it would not be better to have the louvres only on the sides and at over the air intake for the heater/aircon.
Do you mean like the “reduced louvres” as on my 2005 4/4 ...?
Page 3 of 3 1 2 3
