7 members (Jensen1960, Stephen888, John Winn, John V6, Pittsartist, JMcL, JohnHarris), 299 guests, and 26 robots.
+8Rich 102
John V6 59
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,179
Georgetoad, woolfie
#512575 10/05/18 03:04 PM
sprinty Offline OP
Could anyone tell me which fuse controls the windscreen wiper and washer on the 4/4 sport. The fuse diagram has a large ECU stuck on it!
Thank you, John
Morgan 4/4 Sport Competition
Looks like number 8, 10amp on my wiring diagram
Taken from '4/4 chassis harness post 2014'
Just in case they used a +4 harness, that's would be number 12, same rating of course
sprinty Offline OP
Thanks, will have a look
I forgot the number of the fuse on my 2014 4/4. But don‘t be surprised if the new fuse should blow in a couple of days. I changed it for 4 times. The fuse was the first symptom to tell that I needed a new wiper motor.
On my car if you open the top of the fuse box it is described inside the top which fuse is for which function.
sprinty Offline OP
Thanks Heinz, they covered the fuse diagram when my 4/4 was updated to Competition Specification
I was told by MMC that the diagram may bear no resemblance to what is actually in the box - depends who wired it up. This was after all my sidelights went 5 years ago - turned out to be the switch.
By the way I am having the inline fuse fitted to brake lights as suggested at DHF - due to shortage of staff the sprigs are being replaced in 2 weeks.Thanks for the heads up.
Like the Leonardo da Vincy workshop - depends which aprentice was handling the brush.
Your Morgan is a work of art; in part by the master; in part by the aprentice. sherlock
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
