0 members (), 213 guests, and 34 robots.
+8Rich 102
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#516045 03/06/18 04:18 PM
Tom3W Offline OP
What is best to clean the acrylic sidescreens? Thanks in advance.
once: Black M3W with „Jaffa“ leather; 2015
now: Sport grey 4/4 with black leather; 2017
I use a liquid window cleaner & a soft cloth.
Are you wanting to clean a widescreen that is fundamently OK but just dirty , or are you after do a complete renovation job?
If the former then John's suggestion above is good , but there is always an area between the two pieces where they overlap which is difficult to access unless you remove one of the pieces.
If the latter then is best to get specialist advice , crazed and cracked perspex is not easy to recondition, and often it is better to start afresh rather than waste hours on a job that will yield disappointing results at best.
Andy G
1999 +8 , Indigo Blue.
Tom3W Offline OP
@John V8:
On most of the liquid window cleaner is a sticker like: "not for acrylic"
@MOG 615:
It is an new car (2017) with only 1.500km. It is just about cleaning...
Normally I use products from Meguiars, but they have nothing special for this usecase...
I just use regular car shampoo (Meguiars Gold Class) when I wash it, and standard glass cleaner (Autoglym Fast Glass type stuff) if they need a clean in between washes.
Never use anything other than a good shampoo whole car wash and finish off with a good chamois for everything starting with the screens - I'm not a convert to the spray market.
I use AutoGlym Fast Glass on mine. It is not abrasive and brings them up a treat removing all the water marks that are left over after a wash and leather.
Costock, UK
Disco 5
Black Rat
Black Rat
Soft top window cleaner, works for me.
Keith
2013 narrow bodied + 4 Ruby.
I’ll second Autoglyms Fast Glass
The problem with Acrylic is that it can scratch easily so plenty of Fast Glass sprayed on them use a clean microfibre lightly so that the static on the microfibre pulls off the dust and dirt, then using another clean side of the cloth, dry to finish so you are not grinding in the dirt
You can treat acrylic like paintwork so Detailers work well as well using microfibre cloths
I’m particularly hooked on Meguairs Ultimate Quik Detailer as it’s hydrophobic so it will repell and bead water
Stewart,
I do follow up with quick detailer over the whole car including side screens.
The window cleaner I use is non abrasive.
