7 members (Pyewacket, Oliemog, Morganmike, Grumpy2, DJC, Graham, G4FUJ, Lordofthewings),
134
40
Topics49,911
Posts838,143
Posts: 99 |
What is best to clean the acrylic sidescreens? Thanks in advance.
once: Black M3W with „Jaffa“ leather; 2015 now: Sport grey 4/4 with black leather; 2017
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
I use a liquid window cleaner & a soft cloth.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Are you wanting to clean a widescreen that is fundamently OK but just dirty , or are you after do a complete renovation job?
If the former then John's suggestion above is good , but there is always an area between the two pieces where they overlap which is difficult to access unless you remove one of the pieces.
If the latter then is best to get specialist advice , crazed and cracked perspex is not easy to recondition, and often it is better to start afresh rather than waste hours on a job that will yield disappointing results at best.
Posts: 99 |
@John V8: On most of the liquid window cleaner is a sticker like: "not for acrylic" @MOG 615: It is an new car (2017) with only 1.500km. It is just about cleaning... Normally I use products from Meguiars, but they have nothing special for this usecase...
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
What is best to clean the acrylic sidescreens? Thanks in advance. I just use regular car shampoo (Meguiars Gold Class) when I wash it, and standard glass cleaner (Autoglym Fast Glass type stuff) if they need a clean in between washes.
Posts: 37,486 Likes: 993
Posts: 37,486 Likes: 993 |
Never use anything other than a good shampoo whole car wash and finish off with a good chamois for everything starting with the screens - I'm not a convert to the spray market.
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
I use AutoGlym Fast Glass on mine. It is not abrasive and brings them up a treat removing all the water marks that are left over after a wash and leather.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Soft top window cleaner, works for me.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I use AutoGlym Fast Glass on mine. It is not abrasive and brings them up a treat removing all the water marks that are left over after a wash and leather. I’ll second Autoglyms Fast Glass The problem with Acrylic is that it can scratch easily so plenty of Fast Glass sprayed on them use a clean microfibre lightly so that the static on the microfibre pulls off the dust and dirt, then using another clean side of the cloth, dry to finish so you are not grinding in the dirt You can treat acrylic like paintwork so Detailers work well as well using microfibre cloths I’m particularly hooked on Meguairs Ultimate Quik Detailer as it’s hydrophobic so it will repell and bead water
Stewart, I do follow up with quick detailer over the whole car including side screens. The window cleaner I use is non abrasive. John
