5 members (BobtheTrain, John V6, TalkMorgan, +8Rich, Graham, G4FUJ), 327 guests, and 41 robots.
+8Rich 63
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,766
#518381 19/06/18 11:40 PM
Shooter Offline OP
New sump guard
Fitted a new sump guard to the S5. This design is attached to the chassis rather than the engine and there is about 10-15mm gap between the sump and the guard. Of course, drops the ground clearance a bit more!
8 Comments
Shooter #518386 20/06/18 04:05 AM
That looks very robust 👍
Martin (Deano)
Shooter #518397 20/06/18 06:47 AM
Hope mine clears the bump onto the Portsmouth/St Malo ferry early July , will watch the Lotus chaps method .
Shooter #518411 20/06/18 08:13 AM
And has a marketing message for hedgehogs. smile
+8 4.8
Neilda #518429 20/06/18 11:05 AM
laugh2
Neilda #518434 20/06/18 11:21 AM
I wasn't allowed to put a SiFab logo on RTCC's design blush
First one I've seen fitted
Simon @ SiFab.co.uk
Shooter #518630 21/06/18 08:37 PM
Simon, you need to design one for the latest 3.7 Roadster, only had mine a week and the gearbox drain plug is scraped
One that extends to cover that and give a 'ramp' over the cross-member would be good
Do watch that drain plug on your 3.7. The plug on my 8 was similarly scraped when I first had it and the garage found that it had been subjected to enough force to twist it and it was losing oil.
Thankfully my sump guard (Wolf) has saved my engine many times already.
+8 4.8
Shooter #518753 22/06/18 04:40 PM
Luckily my Plus8 has the steel Rover sump. It has a decent dent caused last year by a large stone in the road. If it had been aluminium then frown shocked2
Next oil change I will probably drop the sump for a new gasket as the one there is starting to show signs of oil weeping. Perhaps a chance to bash the dent out a bit too. In the past any grounding has been on the chassis cross member.
