0 members (),
258
91
Topics49,847
Posts837,389
Posts: 1,646 Likes: 1
New sump guard
Fitted a new sump guard to the S5. This design is attached to the chassis rather than the engine and there is about 10-15mm gap between the sump and the guard. Of course, drops the ground clearance a bit more!
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Martin (Deano)
Posts: 5,587 |
Hope mine clears the bump onto the Portsmouth/St Malo ferry early July , will watch the Lotus chaps method .
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
And has a marketing message for hedgehogs.
+8 4.8
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Posts: 1,415 |
And has a marketing message for hedgehogs. I wasn't allowed to put a SiFab logo on RTCC's design First one I've seen fitted Simon @ SiFab.co.uk
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Simon, you need to design one for the latest 3.7 Roadster, only had mine a week and the gearbox drain plug is scraped
One that extends to cover that and give a 'ramp' over the cross-member would be good
One that extends to cover that and give a 'ramp' over the cross-member would be good Do watch that drain plug on your 3.7. The plug on my 8 was similarly scraped when I first had it and the garage found that it had been subjected to enough force to twist it and it was losing oil. Thankfully my sump guard (Wolf) has saved my engine many times already.
+8 4.8
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Luckily my Plus8 has the steel Rover sump. It has a decent dent caused last year by a large stone in the road. If it had been aluminium then Next oil change I will probably drop the sump for a new gasket as the one there is starting to show signs of oil weeping. Perhaps a chance to bash the dent out a bit too. In the past any grounding has been on the chassis cross member.
