6 members (MartO, BobtheTrain, gomog, JohnHarris, Moggo, Grumpy2), 418 guests, and 71 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
herman Offline OP
Need Urgently code, make, and type nrs to order:
-Distributor cap
-Ignition points.
-Rotor arm-
- Condensator
- Spark plugs
Morgan 4/4 1.6 14/04/1978
Nr chassis= B4185
Nr Engine Ford 7k18-A2513
Many thanks in advance. Herman.
Herman ,8500 Belgium-
Morgan 4/4- 1.6- 4/1978 -2 seater. dark blu.
Herman,
There should be a number on the side of the distributor.
Not sure about Morgan installations but the Ford X-flow was fitted with several different distributors over the years.
See: https://www.burtonpower.com/Default.aspx
Cheers,
