10 members (nestor59310, MartinB60, Guten, Graham, G4FUJ, +8Rich, Fuel.inj, James B W, 2949olivier, sprinty, MartO), 298 guests, and 40 robots.
+8Rich 92
Posts837,279
#519292 26/06/18 03:40 PM
E
E
i am looking for dash pictures of Air Conditioners / vents for a new plus 4 or roadster.
thanks
Ciao Ed
Welcome to the forum
The air conditioner and heater vents are in the footwell in front of the gearlever (either side of the stereo space) and on either side of the same black plastic box.
You could run tubes up to the dash but I have never seen it done.
E
E
Come on, nobody has a new Morgan with A/C and has a camera?
thanks...................
Most likely nobody has an A/C with vents in the dash🙈
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Ed it is pretty rare I think you are finding - I don't know anyone with it in 14 years of ownership. Vents in the dash don't exist.
Good Luck
As others have said, I suspect you're looking for pictures of something that doesn't exist. There aren't even windscreen demisting vents in newer cars, as it proved too much like hard work to route the vent pipes past the redesigned scuttle when the rollover protection hoop was brought in (probably around 20 years or so ago now, late 1990s?).
Have a browse through the pictures on the Dashboards thread http://www.talkmorgan.com/ubbthreads.php/topics/140029/Traditional_Morgan_Dashboards (bearing in mind several of the older pics were lost when Photobucket blew up) - I suspect you'll find not a single dash-mounted air vent in any of them.
Doug
1985 4/4 4str, Jubilee Blue
The windscreen demisting vents were deleted when the long doors came in. There was not enough room on the much narrower scuttle top with the long doors from autumn 1997 onwards. Heated windscreen was the replacement for demisting.
I haven't seen any dash vents for cars with a/c and I get to see quite a few traditional Morgans. I'll take a closer look when I'm at MMC next week.
Black Rat
Black Rat
I have airco on my 2013 +4, there are no vents in the dash the cold air comes from the same vents as the hot air ie down in the footwell.
Keith
2013 narrow bodied + 4 Ruby.
Same here, I have aircon in my +4 just the same vents as everyone else.
2017 Metallic Black +4 GDI
I have an Aero +8 and there are no vents in the dash.... the vents are just above the transmission tunnel and rather hidden. I also had a new Roadster - which was the same.
+8 4.8
