2 members (Luddite, Nickplus4), 399 guests, and 28 robots.
+8Rich 92
Posts837,284
When I had my new dash made I did consider the possibility of fitting vents to the dash but the lack of a suitable vent to use rather cancelled the idea. I have since considered the idea of running a tube with a rather elongated and flat outlet under the dash towards the doors on either side, if that makes any sense. It would be just about invisible but may interfere with knee space. I'll probably just leave things as they are.
Definitely, no vents in a traditional Morgan with Air Conditioning.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
This is very redolent of the "waterless" thread I'm thinking grin2..
...except that we seem to have driven the OP away. He's not posted since his second post in this thread bemoaning the lack of photos of the mythical dash vents.
Good 'Evans, that's a bit fishy.
Doug
1985 4/4 4str, Jubilee Blue
I think the dash air con vents are just above the traction control button, next to the tyre pressure warning light
evil
By the ABS light & the seat memory button
E
E
i didn't asked about vents, it's good to know that they are in the footwell. i was concerned there might some type of a/c unit under the dash, like an add on.
now i assume that there is a button or switch on the dash? Right?
since the a/c is listed for 2161.95 on Morgan's option sheet and all i wanted was to see what it looked like
ed
So Ed, this thread did get a bit lost. I'll try and help a little. Dont know about the current models but my 2012 plus 4 (without aircon) has the aircon button on the dash (top right button) but it does not light up with the background lighting, so is kind of secret. However, it does light up when I press it. The electronics are there behind the dash on the circuit board.
Under the bonnet, the heater box has space for the cooling matrix, with stubs of pipes running in and out of the sides of it. Thus it would cool air going into the box under the dash. Of course none of the compressor, radiator or pipework is there. I did wonder about a retro fit but it was a bridge too far
Ed,
Gamablunga has it fitted I am sure he will help.
