2 members (+8Rich, DaveK),
324
34
Topics49,904
Posts838,087
Posts: 625 |
I ordered a script badge for the rear of the car as mine has never had one. What I got looks like it’s been cast by an amateur, then quickly laid on an 80 grit sanding belt, given a quick buff, then badly plated. You can see all the sanding scrapes and the casting has loads of sharp, nasty casting dribbles out of every side. Is this what it should look like or have I been supplied a cheap Asian knock off? It’s not going on my car for sure, I would not even grace my shed wall with it.
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
If it is that bad it must be original!  Sorry - just joking 🙃 I would not accept this quality
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
What a let down. Spoils the experience when something shoddy happens
SFG 2012 4/4 Sport
Posts: 382 Likes: 3
Posts: 382 Likes: 3 |
I would return it to your supplier for replacement.
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
The one on my 2013 car looks significantly better than the one you have - suggests it's not genuine.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The Plus 8 badge I got from MMC (Tarka didn't have one for some reason) is well cast and polished before chroming. Not Rolls Royce quality, but it is at least metal and not chromed plastic....
Posts: 990 |
I have an identical style badge gracing the glove box on my car - it was new old stock genuine Morgan apparently - from ebay several years ago. It appears to be much better quality than the one pictured - maybe its a fake or just a poorly finished one?
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 625 |
Thanks for your replies everyone, I have emailed the supplier here to request a full refund. I was so disappointed that I had not even noticed that it has been cast with bent legs on both the M & N as well. Cheers John
Posts: 37,484 Likes: 989
Posts: 37,484 Likes: 989 |
John, If you like I 'll purchase one over here and send it on to you no problem to ensure you hopefully get a good one.
Take it steady with the back.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Thanks for your replies everyone, I have emailed the supplier here to request a full refund. I was so disappointed that I had not even noticed that it has been cast with bent legs on both the M & N as well. Cheers John John, This didn't come from Morgan Cars Australia surely...
