Topics49,863
Posts837,548
Posts: 146 Likes: 3
It took 37 Years! L - Learner Plates On
Posts: 146 Likes: 3 |
Driving down the M27 the other day the engine suddenly cut out and the tachometer dropped immediately to zero. I coasted to a halt, waited a couple of minutes, restarted the engine and off I went. This was repeated five times on and off the motorway before it finally wouldn’t start at all and the car was recovered to home.
I’ve discovered a dodgy connector joining a single wire from the ignition switch to two other wires (a Lucas WT74 double bullet connector) which I’ve replaced and I’ve by-passed the isolator switch in the passenger footwell and now the engine starts.
My concern is that I’ve addressed a couple of possible causes but wonder whether there are others I should look at before going too far. The next big trip is to France and I’d really rather not have a known problem recur then.
Grateful for any ideas.
Mark
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Mark
It is a long time since I worked on a Kent engine , but I seem to remember that the ballast resistor in the ignition circuit was more often than not a culprit when it came to intermitent electrical faults. I must admit that I can no longer remember the best fix , but Google it and see what comes up.
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
The ballast resistor comes up on here regularly. I am sure others will get back to you
Posts: 37,420 Likes: 978
Posts: 37,420 Likes: 978 |
As John says this has come up as an old favourite on here.
I've known ignition coils to break down in the heat too.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
There is a school of thought that the best thing to do with the ballast resistor is to do away with it but having said I've never had a problem with the one fitted to my 1972 4/4.
I think you've probably identified the root cause of the breakdown being a loose connection. I've never been a fan of bullet connectors but what can you do other than to carefully check each connection and clean if necessary. I do this as part of my pre MoT spanner check. I use a small glass fibre pencil There was also spate of badly fitting female bullet connectors on the market a few years back which wouldn't grip the bullet and required a pinch with a pair of long nose pliers!
Is the isolator switch in the footwell a later addition? Presumably its cut into the low tension circuit?
Might be worth taking a spare coil, ballast resister and condenser with you though as they take up minimal space!
Arwyn
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
Previous posts will indicate that I had a similar problem on a '71 4/4 fitted with Lumenition electronic ignition. I bought and fitted a new coil and ballast resistor but after installation I found that the car wouldn't start at all. I then found that the "king" lead (coil to distributor) had a possible break in the carbon core. I fitted an old lead I had kicking around and the car started instantly and has run without interruption so far.
Posts: 146 Likes: 3
Thanks all.
Looks like I should replace ballast resistor, coil and king lead, just in case.
I suspect the isolator switch in the footwell is a later edition. It is the first point on the positive side from the battery.
Mark
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Try checking the voltage on the positive side of the coil, the ballast resistor should knock it down to 9 volts. Have you thought of changing to electronic ignition? I've had an Aldon Ignitor on mine for nearly 20 years which hasn't missed a beat.
I agree with Arwyn about the spares and a copy of the wiring diagram would also be a good idea.
1972 4/4 2 Seater
Posts: 146 Likes: 3
One further question - any idea where the ballast resistor is located, please?
I haven't ever owned a car of your period but you are looking to trace the White/Yellow lead from the SW connection of the coil and you should find it according to the diagram below. http://www.gomog.com/allmorgan/wiringdiagram1969to1973.jpg
