0 members (),
224
45
Topics49,911
Posts838,152
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Dave yes they are very polite about when they go.
Posts: 83 Likes: 3
Posts: 83 Likes: 3 |
Thats interesting, since I renewed my battery recently in my 2011 S3 3 litre roadster the ecu light has not come on. Oh dear thats probably the kiss of death!
AndrewD 2023 Lagoon Blue Plus Four 2019 Jaguar F Type 2024 Ford Puma ST Line X
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
That's exactly what happened with my battery at twelve years old......... Total unexpected failure....in the garage!!! OK you’ve convinced me - I’ve just ordered a replacement for my 13 year old battery from Tayna. Thanks for the link - I struggled to find a supplier when I looked a couple of years ago. It does go against the grain of my “if it ain’t broke why fix it” policy - especially as it’s one of the few things on the car which hasn’t broke
Ken
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
It does go against the grain of my “if it ain’t broke why fix it” policy - especially as it’s one of the few things on the car which hasn’t broke Seen in The Dalesman: "A don't know what all the fuss about Brexit is. If tha brexit, tha fixes it.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Danger here of assuming that the weak mixture signal is a complete error and the issue is low voltage possibly through a tired battery but more likely through bad connections. The cold and damp comment suggests the latter.
In the OPs place I wouldcheck the battery voltage with a meter - after a nice run in Italy its unlikely that the voltage would be low enough to cause this sort of issue but still eventually start the car. Maybe try out a new battery from the other family vehicle?
The danger is that a weak mixture can cause a hole in the piston leading to other nasties. But if its a typical issue with Roadsters, its more likely the result of a Morgan exhaust system putting the exhaust sensors in a different location to that the Ford ECU was programmed for.
