3 members (+8Rich, DavidR, M3WMW), 218 guests, and 32 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,149
Georgetoad, woolfie
John V6 Offline OP
Dave yes they are very polite about when they go.
Thats interesting, since I renewed my battery recently in my 2011 S3 3 litre roadster the ecu light has not come on.
Oh dear thats probably the kiss of death!
AndrewD
2023 Lagoon Blue Plus Four
2019 Jaguar F Type
2024 Ford Puma ST Line X
U
TM Photographer of 2008
U
Originally Posted By DaveW
That's exactly what happened with my battery at twelve years old.........
Total unexpected failure....in the garage!!!
OK you’ve convinced me - I’ve just ordered a replacement for my 13 year old battery from Tayna. Thanks for the link - I struggled to find a supplier when I looked a couple of years ago.
It does go against the grain of my “if it ain’t broke why fix it” policy - especially as it’s one of the few things on the car which hasn’t broke laugh2
Ken
Seen in The Dalesman: "A don't know what all the fuss about Brexit is. If tha brexit, tha fixes it.
Best Regards
Lang may yer lum reek
Danger here of assuming that the weak mixture signal is a complete error and the issue is low voltage possibly through a tired battery but more likely through bad connections. The cold and damp comment suggests the latter.
In the OPs place I wouldcheck the battery voltage with a meter - after a nice run in Italy its unlikely that the voltage would be low enough to cause this sort of issue but still eventually start the car. Maybe try out a new battery from the other family vehicle?
The danger is that a weak mixture can cause a hole in the piston leading to other nasties. But if its a typical issue with Roadsters, its more likely the result of a Morgan exhaust system putting the exhaust sensors in a different location to that the Ford ECU was programmed for.
