Topics49,859
Posts837,475
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
Just like the "The Mousetrap".....
Posts: 898 |
The engine was delivered to Morgan in a crate with no antifreeze. Do you know that Morgan use that antifreeze.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Thanks all for your observations. I may take a couple of litres out and top up with water. I have not done the maths but I think that would be about right. I have not mixed different antifreeze as they are both Ford premium and I had the good sense to mix a sample first to ensure they were compatible. Ford apparently only make / sell one type of anti freeze now. You can get a dinky little tool for optically measuring the antifreeze to make sure it's the right mix. Much better IMHO than the Specific Gravity types.
Posts: 83 Likes: 3
Posts: 83 Likes: 3 |
I cannot be certain that it was Ford antifreeze that was in it but the handbook does say use Ford Premium and that is what I did. I know its a Morgan and nothing can ever be taken as read but I do know from my test that old and new mix.
AndrewD 2023 Lagoon Blue Plus Four 2019 Jaguar F Type 2024 Ford Puma ST Line X
Posts: 120 |
Hi, quick question , im considering the exact same mod to my Roadster, does the rad from Sifab come with all the bits and piecesfor fixing and connecting and was it a simple job?
regards Steve
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS Triumph Thunderbird 2000 Volvo XC 60 x 3 Volvo C30
Posts: 1,415 |
regards Steve Yes it does! Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Ford Premium AF has changed colour from a bluey purple to a purpley pink............ It mixes OK based on my tests.
