0 members (), 313 guests, and 32 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#522944 18/07/18 02:40 PM
kriss Offline OP
hi Guys
Have been thinking about a bit more power But not stage 3 area What are peoples opinions on up grade How far is sencable for a bit more fun and value for money Who would you recommend??
kriss #522948 18/07/18 02:47 PM
May I be the first to recommend the Garage 56 Stage One exhaust & 'Spitfire' air filter cover. This is easy to fit and makes a massive difference to how the engine runs. love
Andy
kriss #522959 18/07/18 03:43 PM
+1 for improving the exhausts and, to a lesser extent, the air cleaner.
Garage 56 or MMC stage 1 will both let the engine breath better, run smoother and significantly reduce the temperature of the exhaust headers.
The next step would be higher lift camshafts and a mappable ECU to bring it up to Stage 2. Either DIY or dealer fit the Garage 56 kit or Krazy Horse with dyno tuning are the preferred options.
I've had MMC stage 1 for the last couple of years and am booked into Krazy HOrse for the cams and dyno next week smile
Red Leader drive
Chris99 #522971 18/07/18 04:40 PM
SBM Offline
Originally Posted By Chris99
... am booked into Krazy HOrse for the cams and dyno next week smile
Nice one, Red Leader..!!
kriss #523001 18/07/18 05:51 PM
MMC stage 1 kit was everything I needed for massive fun.
Little bit noisy but soooo much better. I don‘t remember if the air filter was part of the upgrade or if I did it seperate but that had been changed too
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
The Austrian #523020 18/07/18 06:52 PM
The MMC Stage 1 is exhaust pipes and air filter. Definetly a worthwhile upgrade, the engine breathes so much better, and runs cooler.
One thing to bear in mind is the exhausts are designed for 2014 cars onwards, so if you want to continue to use heat shields you will need new exhaust mounting brackets and new heat shields, as the heat shields are mounted from the brackets rather than mounted on the silencers.
When I did mine the MMC price with new heat shields and brackets was comparable to G56
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Rog G #523037 18/07/18 07:58 PM
Good point on the new brackets for the MMC stage 1 - I'd forgotten about those.
Red Leader drive
SBM #523038 18/07/18 07:59 PM
Red follower in this case - I blame Skullmog, R1NGA and PaulR for leading me astray innocent
Red Leader drive
kriss #523131 19/07/18 12:08 PM
WW11 MOG
WW11 MOG
Maybe also get a set of Roller Rockers fitted while you’re at Krazy Horse Chris 😉
WarBird #523154 19/07/18 02:29 PM
+1 Well worth it !
