2 members (Luddite, IcePack),
327
83
Topics49,872
Posts837,704
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Buy some larger diameter discs from the car spares place obviously with same hole spacing and dish and get you local machine shop to turn them down. That should be a lot cheaper Always assuming that you can find the right discs and the right machine shop that doesn't have a standard half-day setup fee regardless of the number of operations to be done. Easiest is to just do the decent thing and buy a pair of discs from your local Morgan aftermarket specialist and support small business. After all £70 for a pair of discs every 20 years or so is hardly going to break the bank, is it?
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Good ethos, that.
Aftermarket specialists become specialists by going out on a limb and making the specialism their full time job, and without them we'd all be worse off..
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I did the same some time ago + and 50% more pad contact - what a difference A while ago I had fitted the Mulfab 300mm vented discs, braided hoses and brake reaction bars (four pots caliper standard). Made a big difference,
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I'll do the upgrade as soon as the coast is clear........... On the trip to Silverstone on Sunday the brakes were good, and get better with heat, but no way would they lock the front........
Posts: 469 |
Hi Dave, I also had no problem locking the fronts on the roadster I had, I wonder if your servo/calipers are working efficiently? Ian
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Well it does fine on the brake tester, The tyres were new last year and are very grippy.................
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Dave, you are probably like me....try to avoid HRD braking unless absolutely necessary. My brakes are great and stop the car well. Test ok too. However, a couple of cars pulling out caused emergency stops and locking initially. Some cadence needed.
