3 members (tommog, Ian Wegg, truckin-on), 303 guests, and 39 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Page 5 of 5 1 2 3 4 5
Rog Offline
A healthy supply of salts for the electrolyte needed for the “battery” maybe coming from road salt spray drying onto the pillars, possibly contributing to the staining too.
Roger
Though you may not actually see it, Aluminium will oxidise with a thin coating within seconds after cleaning. That oxide actually protects the metal underneath and is not good at receiving paint. As an aside, when I worked in the electricity supply industry, in order to solder onto aluminium cable sheaths, a stick of abrasive solder needed to be continually rubbed onto the Ali, whilst applying heat, to cut through this oxide coating, whereupon a strong joint could be achieved. Similarly with painting aluminium, you need to break through that oxide coating before paint is applied. The only reliable way is to apply an etching primer and let it dry for a few hours before building up several paint coats on top.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
DaveV Offline OP
2008 Plus 4
Well done, that is looking better than new.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
DaveV Offline OP
We shall see how long it stays that way smile
2008 Plus 4
