7 members (TeddyAds, RobCol, Strathaven, Graham, G4FUJ, teknome, Hamwich, Dougie),
278
93
Topics49,877
Posts837,735
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Odd...
the Aero platform is about as rigid as any modern car. Just checked Tarka: there is about 3mm difference left to right, after 36,000 miles.
Assuming tyre pressures are correct I suspect, as others, a spring issue.
Posts: 595 |
Well I can only say I think I must have totally lost the plot! I measured the height dead centre for each wheel and had this double checked whilst definitely on a flat surface. Today my pal and I got the car on a ramp took all the wheels off and checked the suspension and mounting points, couldn't find anything wrong. Wheels back on we dropped the car back down and hey presto no problem! Drove back to my garage where we took the initial readings and absolutely no problem???? I will still take the car to the factory as soon as possible for a service and checkup. Off now for a stiff drink!!
Worthers +8
Posts: 469 |
That's great news, enjoy, Ian
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 5,587 |
Very glad indeed you are sorted !!
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
Paranoia is one of options fitted as standard on these.
Posts: 5,659 Likes: 5
Posts: 5,659 Likes: 5 |
Can't beat a problem that really easy to fix.
Martin (Deano)
Posts: 37,438 Likes: 983
Posts: 37,438 Likes: 983 |
True, glad you are happier with the car now these things can really worry you at times.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Maybe you had some stiction in the suspension and now it has freed up and balanced out.
Posts: 595 |
Maybe you had some stiction in the suspension and now it has freed up and balanced out. You could well be right, we went for a good run today and checked it on return, absolutely perfect. I'm going to book it in for a service at the factory and will ask them what they think. Worthers +8
