Topics49,871
Posts837,677
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Bad title but it is correct. Ever since my car was rebuilt with a new frame I am getting floor panel vibrations at around 3100 rpm and stopping at 3500 rpm. This is the maximum torque range so the whole car is trying to sing. The new frame arrived with a new floor of aluminum and I suspect loose rivets. I am also looking into the idea of clearing everything out as much as possible, a good cleaning then finishing up with a bead of silicone caulk at all the joins.
Ideas, thoughts or dire warnings?
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
Hi Michael H,
Line the aluminum panels with self adhesive Dynamat. Will eliminate all harmonic vibrations of the panel. I lined my entire cockpit ( behind seats, side panels, floor ) with Dynamat. Made a big difference in noise reduction from vibrations. There are other sound deadening products out there besides Dynamat that probably would work as well.
Loose rivets will probably continue to rattle but the aluminum panels will be quiet.
Posts: 557 |
+1 on Dynamat, great stuff.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Hi Michael H,
Loose rivets will probably continue to rattle but the aluminum panels will be quiet. How did the Dynamat project? Did you get a particular thickness? Difficult to install?
