8 members (jbk, Ricosan, dakri, ChrisP, MartO, IcePack, sezznowt, High Hamster),
407
72
Topics49,880
Posts837,761
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
It might be worth buying a pair of these.... very useful for checking everything is as it should be:  All hail the Wolf guard... I drive mine really carefully over bumps, but it's always catching. This has saved the engine countless times:
+8 4.8
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
I’ve considered one of those but I’m not sure it it’s catching things because it’s slightly lower than what it’s saving
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 37,438 Likes: 984
Posts: 37,438 Likes: 984 |
I’ve considered one of those but I’m not sure it it’s catching things because it’s slightly lower than what it’s saving I agree with you on the new Classics but the pictures above of Nielda's Aero they are essential.
It might be worth buying a pair of these.... very useful for checking everything is as it should be:  All hail the Wolf guard... I drive mine really carefully over bumps, but it's always catching. This has saved the engine countless times:  Where did you source the plastic ramps Neil they look good.
Posts: 853 |
Well after another peep under the car i saw nothing to worry about so set off cautiously but after about 30 miles felt ok to push on home. 3 hour non stop and no probs. Will get her up on ramps tomorrow and have a proper look. I think Peter (Gambalunga) has it nailed as the rear leaf springs are definitely part of the problem as the car sits about 25mm lower on the drivers side. I have been watching the recent posts on the subject as the previous owner had the leaf springs changed at 14000 mls. Now up to 23000 so why so much wear? Still pondering what to do, but it needs to be fixed.
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 526 |
You could use levelling ramps used for caravans/motorhomes. Milenco is a good brand.
Pete
Posts: 9,548 Likes: 133
Posts: 9,548 Likes: 133 |
I bought basic steel ramps from Machine Mart. I use them to lower the car onto not drive up. Safety tip passed on to me....put them facing opposite directions to prevent accidental roll off.
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
I bought basic steel ramps from Machine Mart. I use them to lower the car onto not drive up. Safety tip passed on to me....put them facing opposite directions to prevent accidental roll off. Good tip thanks, never thought of that. Nick
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
SteveT bought a really handy set of ramps at the classic car show. They are flat when you drive onto them and they have a hydraulic jack which you can use to raise the car.
Very handy and a lot easier than traditional ramps. I never liked using mine, I was always worried about driving off the end of them.
