8 members (Lordofthewings, RichardV6, Steve +8, TalkMorgan, Image, aerotaff, uvk33n, +8Rich),
284
96
Topics49,854
Posts837,449
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Brilliant. Looking forward to further updates.
Steve L.
1996 Plus 8 N22 MOG
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
A long way to go .....๐๐๐succes .
Stefan
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Following this thread with excitement.......
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 987 |
Look forward to future updates.
Posts: 14,009 |
Wonderful! Iโm glued ๐ค
Posts: 6,957 Likes: 116
Posts: 6,957 Likes: 116 |
Wonderful! Iโm glued ๐ค Didn't imagine you as a sniffer!
Posts: 514 Likes: 56
Posts: 514 Likes: 56 |
why was the torque reaction bar sawn off? it looks like there was another one at the side of it, how were they located on the axle. I noticed there wasn't a handbrake showing are you fitting a cable handbrake or going electric? I also noticed you have a brake bias pedal adjuster, to use this arrangement on the road the adjuster has to be welded.(so no adjustment) crazy!! following with interest
David Byrne
Posts: 534 Likes: 1
Posts: 534 Likes: 1 |
No idea why the reaction bar has been sawn off but need to find out. Other end attaches to welded on bracket on top if diff casing. Brake bias will be fine for MOT but may be removed anyway as I'm not sure if I actually need it. Postie delivered my new rear panel today, so number plate can be attached after a rather long absence!
Posts: 534 Likes: 1
Progress is being made. Upper part of cage now removed and next will be the under scuttle part of the cage. This will be replaced by a better located under scuttle roll bar and joined by door bars to the rear roll bar. Fuel cell also now removed and our resident expert Simon H will be fabricating a suitably baffled injection tank with twin fillers etc as a replacement. Steering wheel and column removed and I'm now on the hunt for a standard set up to replace the simple quick release wheel/column that had been fitted. Fine for racing but no good to hang an ignition barrel and stalks from. Need to clear the garage of the unwanted spares.....
Posts: 534 Likes: 1
Had a good day on HotMog yesterday. Managed to remove the under scuttle part of the cage, the electric fire extinguisher and the Stack dash. Removing redundant wiring was not easy as it's fully integrated in the loom, which was bespoke made at the time the car was built into a Class A car. It would have been far easier to just terminate the wires but I wanted to ensure the job was done properly and I end up with a car that's a s perfect as possible.  The next image shows the full width radiator. There's an oil cooler behind the rad to the left and a fan to the right.
