1 members (Saxonian), 333 guests, and 29 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
#530055 26/08/18 11:42 AM
JCK Offline OP
Hi,
My left hand drive 1960 Plus 4 regularly develops a small patch of oily deposit on the inside of the windscreen. It accumulates as a light smear right in my line of vision, just about four inches square, but annoying. It is almost lined up with the bonnet louvres, but not quite, and is on the inside. Any suggestions as to where this might be coming from or how it can be getting there? Beats me! Thanks.
JCK
1960 Plus 4 Roadster
It could be being pulled back into the car by air turbulence.
That or you should cut down on the Brylcreme.
Windscreen or aeroscreen?
JCK Offline OP
Windscreen--I should see if it appears on my aeroscreen also.
JCK
Do you have demister vents ? If so, are oil fumes from the engine compartment
getting into the system, due to maybe a leaky or detached air pipe, and then condensing on the cooler windscreen glass?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
