1 members (Carbuilder), 360 guests, and 30 robots.
+8Rich 95
John V6 52
Posts838,016
rockabilly john
Retrobate
Retrobate
Great idea. I have a lot of very tiny but powerful 'rare earth' magnets - will look to see if these can be used, with 'like' poles facing to repel each other...
That would certainly be neater. If it dosen't work & you want to try the spring method, the spring is a standard part at work. Let me know & I will drop a couple in the post.
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
Retrobate
Retrobate
Many thanks for the offer Ian!
The magnets are so small you wouldn't believe, I bought a pack of 20 of eBay for mucking about with, these are flat discs, but they also make small 'rod' ones, so something may well work out.
My dashboard is leather so I made a door to fit the hole and covered it in matching black leather and used a bonnet knob as the pull. Wish I could post you a photo. meabh.
Green & Grown Up
Green & Grown Up
Originally Posted By chris444
I like the new magnetic catches for these, the older door such as my wood dash 99 4/4 is a pain to get open without the key.
I have the pop open type and got a 'Driving Glove' Tab jammed in it while messing about in the garage last week.
No way to open it. banghead It was jammed solid save just being able to get pointed Nose pliers onto the minuscule piece of tab showing and was able to pull it open. Phew, Glove Box, that was a close one. idea
Hi,
my 4/4 Sport (build in 2009) also has the open glove box tilting to the wrong side.
Looks like the factory fits new cars now with a mesh net covering the lower section of the glove box.
Also Melvyn Rutter supplies a leather drape matching the leather of your elasticated door pockets.
4/4 Sport 'Sports Red' (12/2009)
Greetings from Switzerland
Wilhelm
the mesh is just the ticket, holds in all that stuff you can't manage without- String-back
gloves/flatcap/raybans/Leatheman/Surefire torch/liquorice allsorts etc
Like the last one grin2
Wonder if I could get one to retrofit to RTA?
(edit: err, not the Liquorice Allsorts, but a mini cargo net... laugh2)
Cheers,
Chris444
I mounted a piece of wood in the glove box with a spring which bears on the back of the latch. Push the release button & the spring pops the door open about 10mm. See http://www.shirevillageinns.co.uk/mog/latch.jpg
Ian
I did a similar thing, but as the lock was broken, i used a magnet to hold the door shut.
