0 members (),
230
40
Topics49,904
Posts838,083
Posts: 463 |
Would like to install CL but no idea how the factory accomplishes it, would appreciate everyone's feedback and photos. Thanks.
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
Had them installed from new in my 2013 +4.
They are LED lights and I don't find them either very bright or useful.
Had a map light installed at same time and this is far brighter and more useful.
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Would like to install CL but no idea how the factory accomplishes it, would appreciate everyone's feedback and photos. Thanks. The Roadster has three under dash LED lights. A 10 amp fused feed which also supplies clock and radio, runs direct to them with switching via parallel wired door switches in the earth return. The switching feeds into the BCU to provide delay after doors are closed before they extinguish. The four seater has a further two rear lights with switching wired direct so no delay.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The Plus 8 has LED lights under the dash, they are virtually useless!
Posts: 831 Likes: 23
Posts: 831 Likes: 23 |
My 1980 +8 doesn't have any interior lights. And the gauges are darker than a glow worm!
1980 +8 Blue And a few others ---------------- Stephen
Posts: 2,583 |
I have a brilliant one on my 4/4 sport - a small push button torch on my keyring.
Posts: 1,213 |
I stuck a battery powered LED one in the footwell of my 3 wheeler, it worked very well .
Hugh
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
I agree, the lights are not really bright enough and on my Roadster, stopped working on the passenger side. The bulbs look fragile so like others I have installed a flush fitting light over the passenger footwell which is powered by a switch on the radio blanking plate alongside the fan override. Illuminates the whole car !
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
I use the map reading light. Courtesy lights on a Classic Morgan sounds a bit luxury to me  .
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I stuck a battery powered LED one in the footwell of my 3 wheeler, it worked very well . Took me quite a while to find it Hugh. I wonder if the new owner has noticed it. Tim
