1 members (Atlantic),
333
Topics49,915
Posts838,214
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
In a corner, the lateral forces will make the chassis move sideways relative to the rear axle - due to the flex of the leaf springs. Up to a certain point, the tyres maintain their grip, but with uneven tarmac, in the wet or simply because of excessive forces, the grip might be lost for i microsecond. The axle then moves laterally and re-obtains a neutral position relative to the chassis, which then again moves lateral relative to the axle and so forth. Thus an undesired stepwise lateral movement of the rear of the car, which the Panhard rod is meant to prevent. Got it right, or will somebody care to correct me?
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 27,852 Likes: 767
Posts: 27,852 Likes: 767 |
Yes it stops lateral movement. Cheap & very effective on a Morgan. https://en.wikipedia.org/wiki/Panhard_rod
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
An equally effective but even cheaper way is to bolt nylatron blocks between the springs and chassis.
Richard S 1993 4/4 1966 VeloSolex
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Interesting what Wikipedia has to say on Panhard Rods:
“This arrangement is not usually used with a leaf spring suspension, where the springs themselves supply enough lateral rigidity, but only with coil spring suspensions.”
So it must be true!
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 313 Likes: 1
Posts: 313 Likes: 1 |
The nylatron block modification sounds interesting, are there any details on here regarding this pleas?
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
My leaf sprung Jensen CV8 had a panhard rod, oh and 330 bhp!
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
So it must be true! Obviously there is far less resistance to lateral movement in a coil spring than in a leaf spring but that does not mean there is no lateral movement with leaf springs. They will twist and with the underslung chassis of a Morgan, they will twist more when the car hit a bump and the suspension is loaded.
I wonder also if there is a parallel need for panhard rod with limited slip diffs, especially as dragsters sometimes use them. Both my CV8 and Roadster had/have the latter.
So it must be true! Obviously there is far less resistance to lateral movement in a coil spring than in a leaf spring but that does not mean there is no lateral movement with leaf springs. They will twist and with the underslung chassis of a Morgan, they will twist more when the car hit a bump and the suspension is loaded. That’s why my post was tongue in cheek.
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
They also stop your propshaft from hitting the side of the transmission tunnel with a loud thump when taking the long left-hander up Shelsey.
