Posts837,252
Air Filter Box
The air filter of the roadster seems to collect relatively hot air, with an opening right above the gear box and in short distance to the manifold. Indeed the temperature is 30°C above ambient level with spirited driving in 3rd gear. The temperature in the area on the right side of the air filter is lower, especially after removing the part of the sealing underneath the last 4-5 louvres. So I opened the box on the right side and closed the old opening. The incoming is now only 15°C above ambient temperature.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Which version of roadster do you have?
My 3.0 intake is from above the front of the radiator.
Posts: 18 |
That is better, of course, but very difficult with the 3.7, since the area to the radiator is packed!
Maybe worth fabricating a tube to take air from louvres in side of bonnet, you may get further temperature reduction?
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
Maybe worth fabricating a tube to take air from louvres in side of bonnet, you may get further temperature reduction? That's what I am thinking about for my 1993 +4. But I can't deside wether to install a K&N filter or to go for the (colder) side air intake.
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
Maybe worth fabricating a tube to take air from louvres in side of bonnet, you may get further temperature reduction? That's what I am thinking about for my 1993 +4. But I can't deside wether to install a K&N filter or to go for the (colder) side air intake. On my 4/4 Sigma engine I have the ITG air intake, it’s much better than the standard air box with the K&N filter
Craig Jezz
Maybe worth fabricating a tube to take air from louvres in side of bonnet, you may get further temperature reduction? That's what I am thinking about for my 1993 +4. But I can't deside wether to install a K&N filter or to go for the (colder) side air intake. On my 4/4 Sigma engine I have the ITG air intake, it’s much better than the standard air box with the K&N filter Thank you for the pictures Craig. I don't have that clearance above my (Rover T16)engine. So I think I'll have to go for the side or top air intake. The ITG looks a good and solid solution. What's the average BHP gain? I 've already fitted the Librands 4 into 1 manifold.
Maybe worth fabricating a tube to take air from louvres in side of bonnet, you may get further temperature reduction? That's what I am thinking about for my 1993 +4. But I can't deside wether to install a K&N filter or to go for the (colder) side air intake. On my 4/4 Sigma engine I have the ITG air intake, it’s much better than the standard air box with the K&N filter Thank you for the pictures Craig. But I don't have that clearance above my (Rover T16)engine. So I think I'll have to go for the side or top air intake. The ITG looks a good and solid solution. What's the average BHP gain? I’m not sure of exact figures, but altogether with the ITG air induction kit, remap and Librands exhaust it must of added approx 30bhp...
Craig Jezz
Posts: 18 |
This is the reason, why I measured the temperature there as well. It is more or less as high as in the area below the filter. The air is exiting the louvres. This can be seen in the very helpful work of this Morganeer from Texas. There is low pressure. But the air goes into the last 4-5 louvres before the window. There is high pressure!
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
Stonehagen, a simply mod could be John Taylor’s bonnet extensions, they create an opening at the rear of the bonnet, with more airflow. I have them and I think it helps airflow to the itg filter I have on my 3.0 L roadster. Check http://www.morganhoods.com/id69.htmlCheers, Bert
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
