4 members (MartO, Grumpy2, Image, PaulG), 225 guests, and 28 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#532447 11/09/18 01:13 PM
My running boards have been covered with a protective film which has become scuffed by shoes when getting out of the car. I have tried using polish to minimise the marks without success, any suggestions what may help.
Thanks
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Replace the protective film?
Meguiars Plastx.
Works for me with all but the most stubborn of scuffs.
Stuart
Rich Maroon and Royal Ivory (ish) +4
Hi,
I think Isopropyl (rubbing alcohol) is what you need.
Try local chemists (although mine looked rather oddly at me when trying to buy). But it is readily available on Amazon and Ebay.
Hope this helps.
Regards
Geof
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
I know eventually I will need to replace the film but was hoping to find a interim fix.
I have tried rubbing alcohol without any success
Will check out the Meguiars Plastx
Thanks
Tcut works every time. Halfords,
Peter.
Aero plus8 50th Anniversary.
The Tcut idea is interesting, I will try that to see how it compares.
I'm nearing the end of my fourth summer using the Meguiars and there is only one deep gouge that it hasn't fettled. I'm sure that eventually I will get down to the paintwork after constant rubbing but hopefully that will be a good few years off.
Stuart
Riverstar, just replace it, it’s far easier. I’ve replaced the PPF to my running boards twice this year already.
I keep the templates and cut new pieces from a larger sheet. Spray plenty of water mixed with a tinty drop of baby shampoo (I mean tiny) and aplply the film with rubber squeegee (car window tinting tool) and wipe clean with a microfibre cloth..
I’m happy to help, I don’t think we are too far away from each other
Craig Jezz
How easy is it to remove the existing film as would like to replace ours. Has been on their since new.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Craig
- would you mind providing some detail re. what type of PPF you use and a good supplier for same cheers
I need to replace some of mine on the Aero and some of the prices quoted are on the silly side...
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
