0 members (), 247 guests, and 35 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
ChrisR part nr is SSB307 - ignition switch. Look on their web page - thats where I first saw it.
Culminator - its the electrical connections section of the ignition switch - located at the back of the steering lock/ignition switch. You remove the ignition part by removing a tiny grub screw and gently pulling out the wires/switch assembly. No need to remove steering lock complete to get this out.
Hi Ray,
That's great - many thanks !
Chris
Scruffymog
Ray Offline
About four years ago I had problems with this switch on my 79+8. I took it off as said and run the soldering iron over the connections. Never had a problem after that.
Thanks Ray.
