4 members (Image, Fuel.inj, RichardV6, sprinty), 229 guests, and 44 robots.
+8Rich 84
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,366
ChrisR part nr is SSB307 - ignition switch. Look on their web page - thats where I first saw it.
Culminator - its the electrical connections section of the ignition switch - located at the back of the steering lock/ignition switch. You remove the ignition part by removing a tiny grub screw and gently pulling out the wires/switch assembly. No need to remove steering lock complete to get this out.
Hi Ray,
That's great - many thanks !
Chris
Scruffymog
Ray Offline
About four years ago I had problems with this switch on my 79+8. I took it off as said and run the soldering iron over the connections. Never had a problem after that.
Thanks Ray.
