Topics49,843
Posts837,340
Posts: 44 |
ChrisR part nr is SSB307 - ignition switch. Look on their web page - thats where I first saw it.
Culminator - its the electrical connections section of the ignition switch - located at the back of the steering lock/ignition switch. You remove the ignition part by removing a tiny grub screw and gently pulling out the wires/switch assembly. No need to remove steering lock complete to get this out.
Posts: 85 |
Hi Ray, That's great - many thanks !
Chris
Scruffymog
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
About four years ago I had problems with this switch on my 79+8. I took it off as said and run the soldering iron over the connections. Never had a problem after that.
Posts: 534 Likes: 1
Posts: 534 Likes: 1 |
