9 members (TeddyAds, RichardV6, Laurens, Mike D, RedThree, Alistair, JMcL, MartinB60, sbarracl),
329
Posts837,985
Posts: 112 |
Firstly, apologies as I'm sure this subject has been raised before, but for the life of me I can't find the right thread
PROBLEM. I have just replaced the original radiator on my 1967 TR4a engined Plus 4 DHC with a new aluminium one from Mulfab and my thick fan belt and pulleys with the newer thin version. There is insufficient room on the engine side for the old cooling fan and also no attachment points on the water pump pulley, so the obvious answer would seem to be a "Pusher" type electric fan in front of the radiator.
Has anyone done this, if so, what fan did you use and have you had any adverse effects?
Many thanks in advance
1967 Plus 4 Drophead coupe with a TR4a engine
Posts: 37,474 Likes: 988
Posts: 37,474 Likes: 988 |
Is this of any use at all.
http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/519847/Searchpage/2/Main/33535/Words/cooling+fan/Search/true/Re:_Electric_Fan_for_4/4#Post519847
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
A much better solution than a 'pusher' fan is a SPAL fan. They mount direct to the radiator and have a very low profile. They come in loads of sizes, the smallest is only 47mm deep. It has 5 inch diameter blades so you could fit two, one above the other. Available from Demon Tweeks among others.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
SPAL were O/E on plus 8’s at one time, good fans...
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
A much better solution than a 'pusher' fan is a SPAL fan. They mount direct to the radiator and have a very low profile. They come in loads of sizes, the smallest is only 47mm deep. It has 5 inch diameter blades so you could fit two, one above the other. Available from Demon Tweeks among others. https://www.a1electric.com/spal/faninfo.htm I have a Kenlowe on mine but I'd certainly be tempted by SPAL if I was doing it again. Loads of information on this link.
1972 4/4 2 Seater
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
The TR engined +4s can run quite hot , so fan-assisted cooling is good idea.
The standard engine driven fan was never up to much anyway , so don't have any concerns about running without it.
As others have said do not put a fan in front of the radiator, it hinders air flow and stops cooling (the hindrance is proportional to the square of the area of the fan and brackets) The "puller" type fans are much better in this respect , yes they do hinder the air exiting the radiator , but not to the same extent. I would personally go with the SPAL , but others are available. Your radiator may already have the brackets in place, which makes fitment much easier, if not I am sure Peter Mulberry will oblige.
Regarding electrical installation the fan is a high current item, and the early +4s had very little in the way of electrical circuit protection. Be sure to fit both a relay and a fuse it. Although normally controlled automatically by an "otter" switch , some folk recommend a manual override in addition to the auto system. This is easy to install when you do the fitment, it is also a useful check to ensure the fan is working.
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
You mention the "otter" switch which, I think, on most models is placed at the bottom of the radiator which is the coldest. I have put in a mod from Car Builder Solutions" that places the temperature switch in the top hose. Seems to work without the problem of getting the "otter" switch out of the radiator.
John 1992 plus4 connaught green
Posts: 163 |
At the radiator output is the best place for a fan switch as when the temperature rises that tells you the radiator needs help. The input, on the other hand, will always be hot, having just come from the engine, and detecting when the radiator needs the fan on will then be more difficult.
Dave
2008 Plus 4
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Dave's logic is fine as long as the the coolant temperature at bottom hose is within the switch temp range.
Remember though the fan is there primarily to protect engine so sensor on or close to cylinder head feed to top hose would pre-empt insufficient rad cooling, allowing fan to cut in sooner.
Posts: 1,943 |
Many thanks in advance Suggest You look at installing a Honda thin fan with shroud on the inside of Your radiator. You do this by extending the rad perches and moving the rad forward. Contact Me offline and I will send You information. wmbutton@gmail.com BTW: this is a U.S. product called "Flex O Lite".
Button
