9 members (cerealsurfer, Gonze, Neville1, Zach, SwissMogFan, TBM, MartO, +8Rich, Clipper),
240
95
Topics49,869
Posts837,664
Posts: 1,035 Likes: 36
Posts: 1,035 Likes: 36 |
Get yourself a leaf spring lubricator.
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
A seasoned member of our local M3W club branch mentioned at the last meet of over lubrication of leaf springs reducing their natural damping ability.
I imagine his thoughts were more relevant to vintage vehicles fitted with inadequate forms of alternative damping but would be interested to hear other opinions.
Rolls Royce used to lap each leaf together to obtain a perfect sliding surface which was then lubricated and covered with a leather gaiter to keep the grease in and the dirt out.
There is a modern alternative to place a Teflon type liner between each leaf to achieve the same effect.
There's no doubt that an unlubricated, dirty leaf spring will provide more damping and less springing but that's not what it's designed for.
I don't quite see how you can over- lubricate a leaf spring.
I grease mine and then wrap them in Denso tape.
Posts: 1,943 |
I have used teflon between the leafs on My +4 for years. But need to oil also. I forget and it is a rusty mess with teflon sandwiched between the rust. Chain oil spread on the top leaf twice a year is the way to go.
Button
Posts: 1,943 |
I have used teflon between the leafs on My +4 for years. But need to oil also. I forget and it is a rusty mess with teflon sandwiched between the rust. Chain oil spread on the top leaf twice a year is the way to go. Sorry I just read mph's solution. Good that is the Deluxe way to go.
Button
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
The greasing till is very integrering. Alas, very difficult to get hold om, ut sees. None om eBay.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 504 Likes: 2
"Tool" and "interesting" it should have been. Damned auto-correction.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Robbie, I found 3 on e bay. Here is one https://www.ebay.co.uk/itm/Terry-leaf-spring-greaser-clamp-2-25-to-3-5-garage-vintage-tool/232955296216?hash=item363d37b9d8:g:segAAOSwbehbuKfU
Greasing Tools.
Just make sure you have enough room around your leaf springs to fit it in.
https://www.ebay.co.uk/itm/Terrys-Leaf-Spring-Greaser-Tool-Rolls-Royce-Bentley-Ford-Austin-Classic-Car/392141699824?hash=item5b4d777af0:g:6DUAAOSwBHJbuf1L
Beat me to it !!
Posts: 504 Likes: 2
Funny, I found only one, the one you mentioned. It seems to differ from the one depicted in this thread, lacking the wedges you force in between the leave. Or is it not properly assembled?
