10 members (+8Rich, High Hamster, MartO, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH, sezznowt), 311 guests, and 106 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
Page 3 of 7 1 2 3 4 5 6 7
mph Offline
Get yourself a leaf spring lubricator.
Online NoMood
A seasoned member of our local M3W club branch mentioned at the last meet of over lubrication of leaf springs reducing their natural damping ability.
I imagine his thoughts were more relevant to vintage vehicles fitted with inadequate forms of alternative damping but would be interested to hear other opinions.
mph Offline
Rolls Royce used to lap each leaf together to obtain a perfect sliding surface which was then lubricated and covered with a leather gaiter to keep the grease in and the dirt out.
There is a modern alternative to place a Teflon type liner between each leaf to achieve the same effect.
There's no doubt that an unlubricated, dirty leaf spring will provide more damping and less springing but that's not what it's designed for.
I don't quite see how you can over- lubricate a leaf spring.
I grease mine and then wrap them in Denso tape.
I have used teflon between the leafs on My +4 for years. But need to oil also. I forget and it is a rusty mess with teflon sandwiched between the rust. Chain oil spread on the top leaf twice a year is the way to go.
Button
Sorry I just read mph's solution. Good that is the Deluxe way to go.
Button
The greasing till is very integrering. Alas, very difficult to get hold om, ut sees. None om eBay.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
"Tool" and "interesting" it should have been. Damned auto-correction.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Robbie,
I found 3 on e bay.
Here is one
https://www.ebay.co.uk/itm/Terry-leaf-spring-greaser-clamp-2-25-to-3-5-garage-vintage-tool/232955296216?hash=item363d37b9d8:g:segAAOSwbehbuKfU
mph Offline
Greasing Tools.
Just make sure you have enough room around your leaf springs to fit it in.
https://www.ebay.co.uk/itm/Terrys-Leaf-Spring-Greaser-Tool-Rolls-Royce-Bentley-Ford-Austin-Classic-Car/392141699824?hash=item5b4d777af0:g:6DUAAOSwBHJbuf1L
Beat me to it !!
Funny, I found only one, the one you mentioned. It seems to differ from the one depicted in this thread, lacking the wedges you force in between the leave. Or is it not properly assembled?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
