Topics49,868
Posts837,640
Posts: 152 |
Just not to be understood wrong - I have used WD-40 (or whatever similar) to facilitate the penetration process, not as a lubing agents. It also was an important moment to analyse where from the squeaking comes from. To locate the squeaking source is sometimes quite difficult. I have disassembled several times the front covers of the leaf spring mountings, as it sounded like a rubber squeaking. Now at least I know it is definitively coming from the between the leafs. I have applied now "Fluid film", which stays "live" and does not solidify as chain spray does and has not bad lubricating abilities. It is also very resistant against water, as it was originally developed for floating ballast tanks of ships.
In the old times, I remember the bikers did not relay just on the chain spray (they always said it stays just on the surface). They "cooked" their chains in hot oil once a year before the saison. Nowadays, the bike chains have on each member O-Rings, so the chain lube does not have any chance to get in. In fact, it protects the chain from outer wear only. So, depending on the individual car and its squeaking character and source, probably chain spray works in the most cases, but not always. Those cases needs an individual solution, maybe a combination of different treatments.
Of course, definitely the best solution is to pack the leaf springs as DaveW described. However, with a lot of difficult work.
Posts: 516 Likes: 58
Posts: 516 Likes: 58 |
if you use fork lift truck chain spray it is a different formula in which the chain spray actually soakes/adheres to the surface of the metal. (sounds like witchcraft ).
David Byrne
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Yes it's only really worth doing on a spring change. When I changed the springs on Bumble, I loosened the centre bolt and left them overnight with gear oil in all the gaps.
Then when wrapped in Denso tape, that's about the best you can do for longevity.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
David Byrne That’s the one I use David
Craig Jezz
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
The best solution may be to spray in ordinary Diesel oil, it seams to get And stick to everything. I have noticed that scaffolding firms store their unused couplings ln buckets of it.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Common recycling used of filtered old engine oil mix it with some petrol spray that on the petrol will evaporate leaving the oil in place. Common on US car forums as advice.
Posts: 152 |
Still also remember that whatever oil (diesel, hydraulic etc.) was used, the old practitioners used to add graphite, namely to avoid squeaking. They said, even if you abandon the maintenance intervals and the leafs get almost dry, the graphite avoids squeaking for some longer time.
Common recycling used of filtered old engine oil mix it with some petrol spray that on the petrol will evaporate leaving the oil in place. Common on US car forums as advice. . That sounds a good cheap idea.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I use Waxoyl, cheap, has good creeping characteristics, lasts for ages and works well....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Common recycling used of filtered old engine oil mix it with some petrol spray that on the petrol will evaporate leaving the oil in place. Common on US car forums as advice. . That sounds a good cheap idea. But be careful of the explosion risk of a mist of petrol. I hope / guess that is done outside.
