6 members (Clipper, Image, TalkMorgan, Grumpy2, James B W, RichardV6), 246 guests, and 35 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
Page 4 of 5 1 2 3 4 5
BobtheTrain #538464 21/10/18 07:04 AM
Hi Bob,
why not take your Motorhome to an industrial estate on a sunday morning? Plenty of corners to reverse around,and no traffic.
Castle Douglas has a nice municipal site near a lake and a short walk to town.
There is an excellent micro brewery in the town.
BobtheTrain #538473 21/10/18 08:36 AM
Originally Posted By BobtheTrain
Originally Posted By sospan
Good luck with the DVLA Bob.
A Taffmogger has a motorhome and tows his Mog on a trailer. Uses the Mog to explore his destinations. Some trips 6 weeks or more.
Our local Noggin place has a few hard standings with hookup points, shower block. A good location for exploring West/Mid Wales. Damn good food there too.
Thank you. I was thinking of towing the MX5 on a spectacle lift but I need to get used to the motorhome on its own first.
Whereabouts is the Noggin place?
The Halfway Inn.
Nantgaredig.
On the A40 between Carmarthen and Llandeilo.
http://halfwayinn-carmarthen.co.uk/
BobtheTrain #538474 21/10/18 08:45 AM
As always, when travelling route planning is key. I took my 7mtr Fiat based motorhome to Cumbria this year with my Plus 4 behind it on a trailer. Absolutely no problems (with the actual towing) and well worth the effort for all sorts of reasons.
The best advice I can give is to buy the best motorhome/hgv satnav you can with the latest updates of course. Then back that up with the latest road atlas and o/s maps. Then research on motorhome/caravan forums asking for advice regarding your chosen route and destination. Check the route via Google Earth then ring up the campsite direct and tell them you will be arriving with a motorome and trailer and ask them to advise on the best approach route.
I did all of the above when going to Ravenglass in Cumbria this year only to find that three different satnavs were trying to send me via an inappropriate route and the campsite advice was not entirely accurate. It was a lovely wooded site but that was the problem, too many trees to be able to reverse a trailer properly when it cannot be easily seen through a small motorhome rear window.
Hope I have not put you off, even without a trailer a motorhome is well worth having and in my opinion you live in one of the best countries in the world to enjoy it.
Nev
brownbaker #538483 21/10/18 09:48 AM
Originally Posted By brownbaker
Hi Bob,
That is exactly what I did with mine. Getting used to a 24' "box" takes a bit of time but with good mirrors you soon get used to it. The Memsahib used to take ours shopping as she could put frozen items in the 'fridge until she got home.
Reg
brownbaker #538484 21/10/18 09:53 AM
Hi Bob,
Thank you. I'm spending a couple of days near the seller to do that. I'm sure he'll have some places he knows.
Best Regards
Lang may yer lum reek
sospan #538485 21/10/18 09:53 AM
The Halfway Inn.
Nantgaredig.
Thank you.
Best Regards
Nevbag #538488 21/10/18 09:55 AM
Originally Posted By Nevbag
The best advice I can give is to buy the best motorhome/hgv satnav you can with the latest updates of course. Nev
Thank you. I've looked at the Aguri sat nav which is specially made for motorhomes with advice on best routes and 300 campsites.
Best Regards
lowebird #538489 21/10/18 09:56 AM
Thank you. What a good idea.
If only I knew how to do multiple quotes in a post!
Best Regards
BobtheTrain #538510 21/10/18 02:44 PM
Simple Bob,
Just click the "Quick Reply" in each post you wish to quote.
In the editing box (will be labelled Quick Reply) you may need to separate the replies - so a "return key" press after [/quote] and before a [quote] will allow you to add your comments in between the quoted items.
It's a lot easier than it sounds - try it and use the "Preview Reply" button to see how things look. You can also remove parts from the quoted items you don't wish to show again (or are perhaps not relevant to your reply).
At the end of practice you don't need to submit your post if you don't wish too.
BobtheTrain #538516 21/10/18 03:23 PM
Make sure you know your campervan height!
Bridges and barriers etc
Will your motorhome Satnav have a low bridge option to help avoid?
