1 members (+8Rich),
311
42
Topics49,897
Posts838,017
Posts: 140 |
I've fitted a motolita wheel but need to fit a resistor to prevent the airbag warning light coming on, does anybody know what the original wheel was fitted to so I can select a resistor with the correct value? Thanks G
Gareth Aero 8 R Nine T 335d BMW Power!
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
Does it look like this ?  This is the wheel in my Series 2 ad I believe they are the same. If so I seem to remember that someone said it came from an Aston Martin, possibly previous V8.
Posts: 1,646 Likes: 1
Posts: 1,646 Likes: 1 |
That wheel was used in S2,3 & 4. I was previously told it had been used by Aston. However, I have seen it in older auto parts catalogues too.
Aero 8 GTN. #10
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Used on the AeroSS, Aeromax and Aero Coupe as well. If I recall right (I deleted the pic) should be the Atiwe type 3 ab 365. There is a sticker anyhow in the back of the lower spoke of the wheel.
Posts: 140 |
Thanks gents, I thought that it was from a bmw which would have made selecting a resistor easy, when I put a multimeter across the contacts it was showing 0.1-0.2 ohms which I doubt, I'll see if I can find a calibrated meter and give it another try.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Can't measure an explosive initiator properly without setting it off!
Try a 1.8 or 2.7 ohm resistor 1/8 watt, not sure but it may require airbag reseting afterwards
Posts: 140 |
Try a 1.8 or 2.7 ohm resistor 1/8 watt, not sure but it may require airbag reseting afterwards Ah that would explain it, thanks, I'll give those a try.
