7 members (John Winn, sewin, The Flitting, BrunswickGreen44, mph, TBM, hugo), 321 guests, and 38 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,335
Members9,215
Page 5 of 13 1 2 3 4 5 6 7 12 13
Ray Offline
Originally Posted By DaveW
But where do you keep it? A bulging pocket??
It’s not that bulky
I just wear regular Levi’s and it fits a treat
Hanky and change in left pocket, keys in right pocket
Wallet with cards and notes on the back of my phone in upper breast inside jacket pocket
Specs in upper outer breast pocket - usually with a small lens cleaning hanky
Simples
with all those things in your brest pockets you could have more attention than Dave in the pub.
They even have a DaveW Morgan orange one
DaveW Offline OP
Oh no..........stop tempting me.......... innocent
DaveW Offline OP
Update.
It took three attempts to sort this.
With the cowl removed and the sensor ring edged outwards, the key worked every time.
First I removed all the overlapped leather on the inside of the cowl and reassembled. That wasn't enough.
So I ground away some of the plastic on the inside of the cowl around the hole and reassembled. That wasn't enough either.
So I ground most of the plastic around the hole to the diameter of the ring, so that the ring now sits just behind the leather trim. No plastic in the way at all............
I also replaced my replacement neoprene around the barrel with leather!!!!!
Hey presto......now I insert the key (without turning) and the immobiliser disarms in two seconds.....one full flash of the warning light, and a second short flash. So far over about half a dozen tests its been consistent............
So time will tell. It appears that age or use affects the coil and transducer and reduces the range. Given that we're talking mm's a tiny reduction in range is enough.
So if it happens when you're out, remember the 20 second rule.
Wipe the black plasic part of the key around the lock barrel. When the light goes out you have 20 seconds to start the engine............. thumbs
DaveW Offline OP
Still working OK! grin2
Thanks for the info, Dave. This happened to my car yesterday (2yr old Plus 4). We were just on our way to a meet, so didn't have time to investigate and had to take the tin-top.
This morning I held the chip closer to the barrel (remembering the 20 second rule), and hey-presto the immobiliser dis-armed and the engine fired up.
Now to sort out a permanent fix .............
Regards
Alan
AP08 MOG
DaveW Offline OP
Good work Alan.
There's something going on at two years it seems........
On my +4 Supersport the chip is not in the key but a separate piece of torpedo shaped plastic on a chain.
The car will only fire up when the immobiliser is held right up to the ignition ring.
DaveW Offline OP
I suspect that will be a Mazda immobiliser Kev.
Maybe the mog battery has dropped enough to effect its range?
Mark - No Longer driving
