1 members (Carbuilder),
133
36
Old Book
Topics49,940
Posts838,603
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Hello All, I am thinking of getting a jointer/planer/thicknesser and am wondering if any of you have experience of them or recommend a manufacturer. Thanks.
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
I bought just a thicknesser, but I suspect it equally applies.... In my experience do not go for a clarke from machine mart. I thought I was saving a few quid but it was so out of alignment I could not adjust it to get it square.
I went for a jet. spare parts are expensive though... I snapped the drive belt and found that out. Then I found a local firm who matched it to a local manufacturer's version that was a fiver.
Thank you Nick. I was looking at a Clarke but will think twice now.
Posts: 199 Likes: 1
Posts: 199 Likes: 1 |
I have never had a problem with any Clarke product, and believe me, there are quite a few red machines in my workshop.
Richard S 1993 4/4 1966 VeloSolex
Posts: 513 Likes: 2
I have Clarke stuff for other things and I too had never had an issue. But on the thicknesser the frame for the feed rollers was really distorted - so much that I could not adjust the rollers to compensate. I took it back to the shop, checked it against another which was just as bad, and they agreed to a full refund.
I have used the Jet extensively now and it has been really good. Apart from a cock-up from me where a long length of timber hit the back of my shed, jammed the machine, and snapped the drive belt!!
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
I've got a Scheppach HMS260 that I picked up (nearly new) on eBay for around £300. On the whole, I've found it to be easy to use, very reliable and capable of producing very fine results. As with all such tools however, it does benefit from careful use because the blades can be easily be damaged by imprudent use of unsuitable timber. Obviously the blades can be changed but it's a bit of a faff. You'll also need a good dust/chip extractor of course!
Andy
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
The Makita thicknesser is superb, but it doesn’t do over the top planning.
Mine did miles of larch planks when I lined the garage.
Posts: 513 Likes: 2
Good point from Andy. Get a dust extractor. I have a record one and use it with the lathe, bandsaw and router table. Makes life so much better
