Topics49,859
Posts837,481
Posts: 378 |
I had twin outlet side exhausts from Infinity - good quality and a hell of a lot cheaper than Librands. The quality was tested when I lost the rear wheel and they acted as skis!!! T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
I have the quad pipe, rear exit Librands system fitted on my Series 1 Aero. I had smaller S/S side boxes (under the running boards) made up locally as the older, larger ones caught on e.g. speed humps, etc. These have cured the 'grounding' problem and as a bonus, have produced a deeper 'growl' to the soundtrack and may have added a little oomph to the performance  I also designed and fitted an aluminium, powder coated diffuser to the rear to fill in that (to my eyes  ) odd gap - (Apologies to those that have seen this photo before !)James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
Take it away James you put us all to shame.
Em
Posts: 140 |
James, I like the diffuser, been thinking about similar for my s3, it's got sidepipes, and a gaping hole at the back, is it just screwed to the underside?
Gareth Aero 8 R Nine T 335d BMW Power!
James, I like the diffuser, been thinking about similar for my s3, it's got sidepipes, and a gaping hole at the back, is it just screwed to the underside? thanks Gareth (and Em !)  Yes, a couple of coach screws at the rear into the ash frame and a couple of S/S bolts with washers/locknuts through two drilled holes in the boot floor. I believe that later Aeros have the petrol tank in the way of the boot floor but I was OK on a Series 1..... James
Posts: 180 |
I had some twin side pipes fitted to my S1 last year. They look & sound great, very much like a C63 AMG merc, thunderous at revs and yet restrained when below 2000 rpm when cruising. Fitted by Hayward and Scott. Interesting was the incredible weight of the old silencers when removed (2 per side) , which I have kept. 40 to 50 kg per side, so some considerable weight saving, but I don't know how much the new single silencers per side weigh. My estimate is an overall 50 to 60 kg saving
Posts: 5 |
Thanks for the info. Plenty of options to look into.
Posts: 11,527 Likes: 312
Posts: 11,527 Likes: 312 |
Don't forget that the changes may adjust back pressure and tune. I have always used the rule that a significant adjustment to the exhaust should be linked with a rolling road ECU map to optimise them. I have a plan to tune the engine in our family car now it is out of warranty but plan to change the exhaust first and then put it through a map change. If you are looking for a custom exhaust fabricator give these guys a call and ask for the name of nearby company they use ? www.mslperformance.co.uk (assumes you maybe be near Brum)
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
I had some twin side pipes fitted to my S1 last year. They look & sound great, very much like a C63 AMG merc, thunderous at revs and yet restrained when below 2000 rpm when cruising. Fitted by Hayward and Scott. Interesting was the incredible weight of the old silencers when removed (2 per side) , which I have kept. 40 to 50 kg per side, so some considerable weight saving, but I don't know how much the new single silencers per side weigh. My estimate is an overall 50 to 60 kg saving Interesting if they all had the same exhaust then, my standard exhaust didn't seem to weigh very much at all..
Aero 8 GTN #11
Posts: 180 |
Don't forget that the changes may adjust back pressure and tune. I have always used the rule that a significant adjustment to the exhaust should be linked with a rolling road ECU map to optimise them. Interesting that you say that. For about 100 miles after fitting the sides pipes my S1 was feeling a little off colour. However, after some intentional stop/starts within those 100 miles, the ECU seemed to relearn the new relocated exhaust sensor inputs and settled down to normal. Car did however seem a bit more lively but I honestly don't know how subjective that is
