8 members (DCH, linklaw, Sir Percival, Mark+4, Tom Sayles, Strathaven, MATTMOG, IcePack),
255
79
Topics49,867
Posts837,622
Posts: 12,260 Likes: 318
Posts: 12,260 Likes: 318 |
Did you check the oil level in the steering box as well? A dash of Molyslip in there also works wonders!
Arwyn I realised that I haven't checked my steering box for well over a year. Not only did I get a whole 65ml tube of Molyslip Steering Box additive in there, I also got another 50cc of 90W gear oil in too. No sign of a leak, though. Note to self - check more frequently!
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Yes I check mine routinely and it always needs a top up, quite odd though as it has no leaks. Where does it go? I use Penrites liquid steering box grease which is really a thick oil that just pourable. Steve
Yes I check mine routinely and it always needs a top up, quite odd though as it has no leaks. Where does it go? I use Penrites liquid steering box grease which is really a thick oil that just pourable. Steve Cheers Steve, I'll try some of that next.
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
Yes I check mine routinely and it always needs a top up, quite odd though as it has no leaks. Where does it go? I use Penrites liquid steering box grease which is really a thick oil that just pourable. Steve Is that readily available.
John 1992 plus4 connaught green
Posts: 17 |
Hello Arwyn i have a 1994 morgan 4/4 which i find the steering getting heavier as i get older, you mentioned lubricating the box,i cant seem to see the filler plug if there is one,i would value any advice. regards sarnia.
Yes I check mine routinely and it always needs a top up, quite odd though as it has no leaks. Where does it go? I use Penrites liquid steering box grease which is really a thick oil that just pourable. Steve Is that readily available. Yes I check mine routinely and it always needs a top up, quite odd though as it has no leaks. Where does it go? I use Penrites liquid steering box grease which is really a thick oil that just pourable. Steve Is that readily available. Sorry John missed this post, it was recently rebranded but I think this is it... https://www.scparts.co.uk/sc_en/steering...ASABEgLkHvD_BwE
