7 members (Alan Patterson, Robbie, Mats, Lance, bmgermany, Image, Chris Cosher), 240 guests, and 42 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,126
Mark H Offline OP
Guys on the M3W, is there anyway you can get the Engine Management light fault code to read on the dash display or do you need a CAN bus reader?
You need a windows laptop with ProTune II and a lead to plug it into the mobile phone type socket under the cover on the ECU.
Avionics.... somestick
Mark H Offline OP
Thanks Ian - much appreciated- I was told there's a requirement to fit a 16 pin connector point under the dashboard - Mmmm
The 16 pin connectors are used on car OBD-II systems, its a mini USB on the S & S, M3W as shown below once cover removed.
Mark H Offline OP
Thanks Richard
Mark, I have an old laptop with protune and the necessary lead you can borrow if you want.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Mark H Offline OP
Thanks Rog
Adding an OBCD port is one of the Euro 4 "upgrades"
Somewhere in the S&S documentation there are instrustions fopr reading the codes via the instrument panel but they don't work on the M3W.
Si it's the old laptop and Protune I'm afraid Mark (or just wait until it goes out again.....)
Red Leader drive
Mark H Offline OP
Thanks guys
One other thought,
As the fuel has been sitting in the tank for a couple of months it might have gone off a bit which could trigger a lambda sensor warning.
Filling up with super might help blow the light out.
Red Leader drive
