1 members (Ian Wegg),
253
Topics49,904
Posts838,088
Posts: 1,671 |
Guys on the M3W, is there anyway you can get the Engine Management light fault code to read on the dash display or do you need a CAN bus reader?
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
You need a windows laptop with ProTune II and a lead to plug it into the mobile phone type socket under the cover on the ECU. Avionics....
Posts: 1,671 |
You need a windows laptop with ProTune II and a lead to plug it into the mobile phone type socket under the cover on the ECU. Avionics.... Thanks Ian - much appreciated- I was told there's a requirement to fit a 16 pin connector point under the dashboard - Mmmm
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
You need a windows laptop with ProTune II and a lead to plug it into the mobile phone type socket under the cover on the ECU. Avionics.... Thanks Ian - much appreciated- I was told there's a requirement to fit a 16 pin connector point under the dashboard - Mmmm The 16 pin connectors are used on car OBD-II systems, its a mini USB on the S & S, M3W as shown below once cover removed.
Posts: 1,671 |
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Mark, I have an old laptop with protune and the necessary lead you can borrow if you want.
Posts: 1,671 |
Mark, I have an old laptop with protune and the necessary lead you can borrow if you want. Thanks Rog
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Adding an OBCD port is one of the Euro 4 "upgrades"
Somewhere in the S&S documentation there are instrustions fopr reading the codes via the instrument panel but they don't work on the M3W.
Si it's the old laptop and Protune I'm afraid Mark (or just wait until it goes out again.....)
Red Leader
Posts: 1,671 |
One other thought,
As the fuel has been sitting in the tank for a couple of months it might have gone off a bit which could trigger a lambda sensor warning.
Filling up with super might help blow the light out.
Red Leader
