7 members (david nathan, Graham, G4FUJ, BobtheTrain, Gordon D, sewin, Rex_tulips, Elliot),
275
42
SORN
New
Topics48,367
Posts813,392
Members9,215
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
But this would happen after the gearbox via a linkage, given the size of the car this is most like after the seats so I would assume it could be either left or right hand drive.
I should add I'm no engineer just a bodger!!!
Slowly going green
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
I thought you being a single-track type would relish a trike without weather protection, you haven't gone soft have you?
[quote=A11OGE]I believe the main market for the 3 wheeler is expected to be the USA, hence HD engine + left hand drive etc. Mind you there has been great interest in the UK. the output shaft is left hand/ rear of the engine when fitted to a motorcycle, turn the engine through ninety degrees and the drive comes through the right side footwell so control pedals have to be on the left Gents are you sure about this, as the engine is a V the output shaft should be centrally located. See below. This will then connect the the gearbox. If the shaft is offset then the gearbox will also be offset which does not appear to case in the pictures on the MMC site. Am I missing something? you make no mention of a clutch - though I'm quite open to other explanations -
Posts: 2,190 |
[quote=A11OGE]I believe the main market for the 3 wheeler is expected to be the USA, hence HD engine + left hand drive etc. Mind you there has been great interest in the UK. the output shaft is left hand/ rear of the engine when fitted to a motorcycle, turn the engine through ninety degrees and the drive comes through the right side footwell so control pedals have to be on the left Gents are you sure about this, as the engine is a V the output shaft should be centrally located. See below. This will then connect the the gearbox. If the shaft is offset then the gearbox will also be offset which does not appear to case in the pictures on the MMC site. Am I missing something? you make no mention of a clutch - though I'm quite open to other explanations - I'm rather more interested in how they are going to mate the Mazda MX5 box to that 'orrible, vibrating pile 'o c**p which is the H-D power plant. As I've siad on this site before- more technical info would be nice. Until then, I'm reserving my judgment
GLLHG
Easter
If you take a look at the video at 1minute 25 they have some drawings, may not be correct but gives some ideas of the set uo.
Slowly going green
Posts: 135 |
that 'orrible, vibrating pile 'o c**p which is the H-D power plant.Say what you mean GLLHG!
Posts: 2,190 |
that 'orrible, vibrating pile 'o c**p which is the H-D power plant.Say what you mean GLLHG! I've paid my dues- I've owned four of their bikes ( which speaks volumes for my masochistic tendencies!)  Cheers, G
GLLHG
Easter
If you take a look at the video at 1minute 25 they have some drawings, may not be correct but gives some ideas of the set uo. I couldn't see prop shaft on that video. As I see it the H-D m/cycle has a chain primary drive[drive from engine to clutch] so engine spins 'forward' [on m/cycles with gear primary engine spins 'backwards'] - so on Mog trike engine will spin anti/clockwise if viewed from drivers seat, therefore prop must connect to wheel on right hand side to propel car forwards, or I am missing something obvious?
Posts: 28,429 Likes: 180
Posts: 28,429 Likes: 180 |
I thought you being a single-track type would relish a trike without weather protection, you haven't gone soft have you?  Sold my Triumph last December Richard. No bike in the garage now... Gone soft? Seem to be going that way  However, I'm still thinking about a mid-size trailie for the odd bit of green laning (if I can find any lanes in Gloucestershire now...). Cheers,
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
I've gone soft - no bike since I sold the KTM Duke, I have the odd twinge if I see a 69 Bonnie but it soon passes
