1 members (+8Rich), 213 guests, and 38 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
#541037 05/11/18 05:18 AM
britmog Offline OP
I know there have been previous threads on the removal of the exhaust baffles and whether there are any improvements or not. Wondered what the conclusion was? Is there a benefit to performance/engine health or the converse downside to performance/engine health?
Would be interested to know?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
britmog #541040 05/11/18 07:02 AM
Removing bufflers:
Performance ++
Better breathing for the engine
Noise ++
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
britmog #541144 05/11/18 07:14 PM
Think you should count on them being exceedingly noisy!
britmog #541187 06/11/18 03:45 AM
britmog Offline OP
The recommendation seems to be to remove or drill holes in the front baffle to increase air flow and increase sound but not too much. My question is where is the front baffle located and how do you gain access to it? I can see the rear baffle and the second one in.
Bruce
2013 M3W (Olga)
britmog #541250 06/11/18 01:58 PM
A 1 inch hole cutter with a long extension, about 12 inches.
Drill slowly.
Remove the silencer and drill from the front.
John.
britmog #541601 08/11/18 09:51 AM
I agree with The Austrian's comment but only drilled the front baffle 38mm. The noise is subjectively not much louder at steady revs but certainly is when pulling.
I needed 2 x 300mm extensions. The steel is very hard, use plenty of cutting lube spray, drill very slowly & dont pull out to check progress. One high quality cutter will do both sides or 2 cheaper ones.
Tim
TimG #541728 08/11/18 09:08 PM
britmog Offline OP
Tim,
Thank you for the reply. I assume you separate the exhaust where the clamp is and drill from the front through the silencer?
Bruce
2013 M3W (Olga)
britmog #541902 09/11/18 07:25 PM
I would say the sound difference is slightly better, the performance is noticeably better, and the header pipes stay much cooler.
kirkusblog.com
1952 Ford 8N
Draggin #541945 09/11/18 11:09 PM
Mine started to crackle and pop on overruns - sounds awesome!
britmog #541953 10/11/18 12:28 AM
Go with Magnaflow!
After many miles and enjoyable cruises I’m very satisfied and have had many compliments on the awesome Magnaflow sound! Many of top custom car builders use Magnaflows and now I know why. Absolutely no exhaust restriction and the originals are on the shelf if I ever decide to sell.
Magnaflow the name says it all!
High Noon
