0 members (), 423 guests, and 87 robots.
+8Rich 81
Topics49,849
Posts837,424
#544215 22/11/18 06:27 PM
Button Offline OP
Does anybody have Alignment Numbers for a 1998 +8:
Caster
Camber
King Pin Inclination (Not sure what this is)
Toe In
Button
King pin inclination is the angle of the king pin as seen from the front of the car whereas the castor angle is the angle of the king pin as seen from the side of the car.
On my 1999 4/4 the angles are as follows. (according to the book but I'm going to check them)
Castor... 4 degrees
Camber... Upright to 0.5 degree negative
King pin inclination... 2 degrees
Toe in... 0 to 3.2mm
No saying the +8 is the same but this gives a guide to the sort of numbers to expect.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Button Offline OP
Castor... 4 degrees
Yes I suspect it is the same but I wonder. Also I would think camber and KP inclination would be the same. So do You know what camber is?
Button
Camber and KPI will not be the same.
The camber is the angle of the wheel and tyre as seen from the front of the car whereas KPI is the angle of the king pin as seen from the front.
In theory they could be the same but in reality, on road cars the KPI will be more than the camber.
This is achieved by not having the stub axle at 90 degrees to the king pin.
So if the KPI is 2 degrees and the camber is 0 it means the stub axle is at 88 degrees to the king pin .(Or 92 degrees depending on which way you took at it)
Bob
2009 Black Roadster
Button Offline OP
I found the Alignment Shop numbers when I finished My +8 Bitsa
Left Right
Camber -.1 -.1
Caster 2.6 3.4
Toe .04 .05
SAI 4.0 4.0
Included Angle 3.9 3.8
I have no idea what SAI is or Included Angle
Button
I have no idea what SAI or included angle are.
SimonH might have an Idea if he sees this.
I think castor looks a bit low but if it works on your car....
Bob
2009 Black Roadster
I think castor looks a bit low but it if it works on your car....
Ah found it.
Check this out
SAI angle
Looks like its an American way of writing it. I.e. SAI is KPI.
Bob
2009 Black Roadster
Button Offline OP
No it does not work for Me. But I am trying to figure out if it is alignment, bump steer or what ever. Probably a combination. I am trying to start out at square ONE. I have put up with this long enough.
Button
Caster
Camber
Toe In
Button, whilst at the Factory today, I specifically asked Mark Baldwin (very knowledgeable & exceedingly helpful with a few snagging issues with mine)
This is how they aim to set up a 'road car' rtm
Camber, 1/4 to 1/2 degree negative, & he feels over the 1/2 would be to much for road use
Caster, same as King Pin inclination, they set up at chassis build by tilting the crosshead to 5-6mm from vertical
Tracking, 3mm toe in
What a brilliant place this is. This exchange demonstrates all the best things about Morgan kinship and this site in particular.
Nick
