1 members (Alan Patterson),
366
85
Topics49,850
Posts837,427
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Whilst you have your wire brush out, check the axle breather hole is clear. It's a small 1/8" hole on one of the Salisbury axle tubes.
If it's blocked with paint or dirt, the axle may pressurise and oil leak past the seals onto the brake shoes.
Arwyn
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Button: looking forward to seeing you in Sun Valley, assuming I make it through the Colorado snows to the start in Newport Beach!!!
Calypso Red: when looking down on the axle the nipple is at 3 or 9 o'clock and the worm hole is on the opposite side at either 9 or 3 o'clock. It can take a lot of grease. I live off dirt roads so get a great deal of crud down there, I use a solvent spray to clean the area.
Posts: 1,943 |
My 1994 +8 has the grease nipple and hole for the "worm"of grease to exit. Just serviced mine ready for the Morgans Over America rally in May. Hi Britmog, I have a 1994 +8 and although I have found the grease nipples on the rear axle just behind the back plate of the brake drums I have never found the "worm" of grease holes dispite persistent searching. Can you describe for me exactly where these holes are on the axle? Thanking you in breathless anticipation...... I clean the little hole with a small drill bit.
Button
