Topics49,921
Posts838,289
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Everyone,
Bit of an update.......
By the use of a quantity of various washers, leather and neoprene strips,and nut tightening I have eradicated many if not most of the rattles.
The rear hood frame latches were a major issue in that they never properly latched allowing the component parts to rattle against each other. So I obtained and fitted a couple of replacements. It was very noticeable the springs have been upgraded, larger diameter and thicker gauge wire, giving a much greater pressure on the sliding part of the latch.
The old latches had considerable damage in the receptor hole at the 1pm position and I can only conclude the weak springs enabled the male prong part of the mechanism to "shake rattle and moan" to the point they were useless.
I now look forward to being out again.
Hope this helps.
Incidentally my car was built at the end of 2006
Regards
Geof
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 383 Likes: 6
Hi Everyone, Just a couple of piccies relating to the hood latches showing the of damage they had suffered and also the later springs that are so very much stronger If anyone has a similar problem I have some idiot notes to help with the replacement fitting. But it's not a hard job to do providing your fingers are it like cows udders. New fitting  Pristine  Nackered
Regards
