2 members (Carbuilder, ChrisConvertible), 165 guests, and 151 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,290
Smed., Spanner Juggler
Page 3 of 3 1 2 3
SALMO Offline OP
Hi Everyone,
Bit of an update.......
By the use of a quantity of various washers, leather and neoprene strips,and nut tightening I have eradicated many if not most of the rattles.
The rear hood frame latches were a major issue in that they never properly latched allowing the component parts to rattle against each other. So I obtained and fitted a couple of replacements. It was very noticeable the springs have been upgraded, larger diameter and thicker gauge wire, giving a much greater pressure on the sliding part of the latch.
The old latches had considerable damage in the receptor hole at the 1pm position and I can only conclude the weak springs enabled the male prong part of the mechanism to "shake rattle and moan" to the point they were useless.
I now look forward to being out again.
Hope this helps.
Incidentally my car was built at the end of 2006
Regards
Geof
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
SALMO Offline OP
Hi Everyone,
Just a couple of piccies relating to the hood latches showing the of damage they had suffered and also the later springs that are so very much stronger
If anyone has a similar problem I have some idiot notes to help with the replacement fitting. But it's not a hard job to do providing your fingers are it like cows udders.
New fitting
Pristine
Nackered
Regards
Geof
Page 3 of 3 1 2 3
