9 members (CBY, BobtheTrain, Ricosan, Davetherave, gomog, Alistair, stumog, RobCol, Graham, G4FUJ),
212
61
Topics49,884
Posts837,837
Posts: 327 Likes: 3
Posts: 327 Likes: 3 |
My father worked for a company supplying power presses to carmakers. I recall him telling me that the outer layer of the steel coils would be rusty so should be cut off before feeding the clean steel into the presses. He turned up at a BL plant one day to see they were just feeding the rusty end straight into the press. He pointed out that the rusty metal was going into someone's car......i don't believe the rest of conversation was constructive.
Tom 2018 Plus 4
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
In Brum we used to refer to the Agro as a HedgePig. Great scene in the Grimleys when they were coming out on strike of the some Allegros they got hold of to mock up the Longbridge assembly line. A taste of the Grimleys is aptly described in this little snippet Their father Baz (former Young Ones actor Nigel Planer) was a bone-idle British Leyland car worker, who injured his back on his first day at the Longbridge plant and went on strike on the second. He has not moved from his armchair since then and spends his days watching television (ITV only). He is particularly infuriated by Gordon's artistic leanings and is determined that he should do "a man's job" rather than go to university, unlike their hard-working mother Janet (impressionist Jan Ravens). I lived that life with my father being what seemed on strike more often than at work. yes from the Longbridge plant. The sadistic PE teacher in the show was just like ours!
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
I used to have a TR3A and loved the car but rust killed it whenI was about 19. I would love another one but am afraid of rust. Can a good one be protected from rust these days. Most have been rebuilt chassis up by now and modern materials will have been used in the process. My own car has had a new chassis and a few new body panels all well protected with cavity wax and other anti rust stuff and a much better finish than the factory ever did. It'll see me out at least. So I wouldn't let memories of rust problems stop anyone from having a classic now, just be certain the restoration has been done well, most have and TR's like Healeys have separate chassis so it's fairly easy to check.
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
I’ve had a TR3 and a TR3A, loved them. The 3’s and 4’s make great classic rally cars, the 4 a bit more civilised maybe. Don’t go for a TR4A though....and don’t buy one without overdrive although if cheap enough can be converted. TR’s certainly don’t rust as bad as Morgans of the same era. As for Allegros a work colleague had a 1750 SS, my 4/4 1600 couldn’t stay with it, most embarrassing...... I know of a nice TR6 for sale not far from Wen’s home if you’re interested. Not expensive.... Good luck in your search!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 537 Likes: 3
Posts: 537 Likes: 3 |
My father worked for a company supplying power presses to carmakers. I recall him telling me that the outer layer of the steel coils would be rusty so should be cut off before feeding the clean steel into the presses. He turned up at a BL plant one day to see they were just feeding the rusty end straight into the press. He pointed out that the rusty metal was going into someone's car......i don't believe the rest of conversation was constructive. I think I had one of those once: a Maxi that was rusty under the paintwork. The doors ended up with holes in them in under 5 years despite attempts to treat the rust. This was in the same year that Volvo's were advertising 17 years life expectancy for their 240s. Interestingly, from memory, they were also advertising the fact that the cars were very largely recyclable and that many of their components including steel items, were sourced from the UK.
Rob T 2017 Tungsten Plus 4
Posts: 5,587 |
My father worked for a company supplying power presses to carmakers. I recall him telling me that the outer layer of the steel coils would be rusty so should be cut off before feeding the clean steel into the presses. He turned up at a BL plant one day to see they were just feeding the rusty end straight into the press. He pointed out that the rusty metal was going into someone's car......i don't believe the rest of conversation was constructive. Oh , Hell , so now we know what caused the rust in those cars from BL in the 70's , idiots !
Posts: 14,009 |
I’ve had a TR3 and a TR3A, loved them. The 3’s and 4’s make great classic rally cars, the 4 a bit more civilised maybe. Don’t go for a TR4A though....and don’t buy one without overdrive although if cheap enough can be converted. TR’s certainly don’t rust as bad as Morgans of the same era. As for Allegros a work colleague had a 1750 SS, my 4/4 1600 couldn’t stay with it, most embarrassing...... I know of a nice TR6 for sale not far from Wen’s home if you’re interested. Not expensive.... Good luck in your search! Thanks 🤓. Wen sends her regards.
Reciprocated! You’ll have to bring your ‘new’ car to the Sportsman’s Arms one weekend !
Posts: 14,009 |
Reciprocated! You’ll have to bring your ‘new’ car to the Sportsman’s Arms one weekend ! We will.....I’ll let you know when we do!
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
My father worked for a company supplying power presses to carmakers. I recall him telling me that the outer layer of the steel coils would be rusty so should be cut off before feeding the clean steel into the presses. He turned up at a BL plant one day to see they were just feeding the rusty end straight into the press. He pointed out that the rusty metal was going into someone's car......i don't believe the rest of conversation was constructive. Oh , Hell , so now we know what caused the rust in those cars from BL in the 70's , idiots ! And you guys reckon Alfas were bad
